Problem with HH4
NikosT
Problem with HH4
Unread post by NikosT » 08 Feb 2020, 12:19
I have a problem with HH4 running on Windows 10. When I try initialize a multi on Omnisphere or Kontakt, I can’t select the confirmation window to initialize multi. It’s impossible to move to the warning tab. Moreover I don’t have this problem with any other DAW. Could you please help?
Thank you
Nikos T
NikosT
Unread post by NikosT » 09 Feb 2020, 07:44
Any answer?
Nikos T
Unread post by nay-seven » 09 Feb 2020, 09:32
We have receive your email about this ( only 24h ago) and will answer you ,
Can you give us a precise example with Kontakt ( omnisphere don't have demo) ?
NikosT
Unread post by NikosT » 09 Feb 2020, 11:45
I sent you my first email 5 days ago and I didn't got any response. In my second email I have attached you a video for you to see the problem. Thank you.
Nikos T
Unread post by nay-seven » 09 Feb 2020, 12:03
Yes, you're right , we miss your first email, sorry for that,
but understand we need to reproduce your issue to solve it, could take more than 5 days ?
i know there's something similar with Reaktor for example , generally moving the windows , let the second one appear. And as said before Omnisphere don't have demo, and no Kontakt users report this before, so not so easy.
NikosT
Unread post by NikosT » 09 Feb 2020, 13:16
Yes, please take your time. I just wanted to know if it’s bug or I did something wrong. Moreover this problem occurs on any NI Komplete plugin and any other VST I use.
Nikos T
secretkillerofnames
Unread post by secretkillerofnames » 07 Mar 2020, 06:29
nay-seven wrote:
09 Feb 2020, 12:03
Yeah I just noticed this with Reaktor. When changing an ensemble the save window is hidden behind the plugin window and locks up HH unless you move the window before change. I don't recall this being a problem in HH3 but it may have been there.
ericzang
Unread post by ericzang » 07 Mar 2020, 10:10
I also have this problem. Win 10 x64
It seems that the plugin is forced to be on top of everything always. I tried switching to the dialogue but still cannot access it. Sometimes the computer keyboard can send keys to the dialogue to close it or select an option, including ESC to abort the dialogue. Also, pressing Window-Tab and closing the dialogue allows me to escape the locked situation. Moving Kontakt away from center of the screen, as noted above, is helpful.
Another work around is to use a function that toggles the "Always On Top" status of the plugin window, and use it to turn on the On Top status of the dialogue. I use AutoHotkey. When kontakt and Usine appear to be locked (when the dialogue is launched in the background), I use this On Top function and then the dialogue window appears on top of Kontakt as it should.
AutoHotkey command:
https://www.groovypost.com/howto/howto/ ... ys-on-top/
Thanks for your help.
Below video is of the problem.
NikosT
Unread post by NikosT » 29 Mar 2020, 23:25
Hi, any news related with this bug?
Nikos T
drakh
Unread post by drakh » 08 Apr 2020, 12:51
NikosT wrote:
29 Mar 2020, 23:25
this is known bug with NI plugins on windows, i am fighting it a lot.
but, there is workaround i am using
on windows, you can use multiple desktops.
so use "win+tab" key combination, you chould see the "invisible" confirmation alert, move, it to another desktop, navigate to that desktop, click whatever button you need, and you should be good to go
NikosT
Unread post by NikosT » 09 Apr 2020, 03:18
Thanks @drakh for your answer. Unfortunately, even though I can reach the 'caution' window with 'win+tab' key combination, I can't hit 'OK' with the arrow or any other key to confirm the command. This problem is a little bit strange because I don't have it with any other software I have. It is also strange because this problem does not exist with Hollyhock 3.
Nikos T
ericzang
Unread post by ericzang » 09 Apr 2020, 10:53
the autohotkey workaround I mentioned above I think is the most convenient workaround once you get autohotkey going.
NikosT
Unread post by NikosT » 09 Apr 2020, 13:56
Hello @ericzang, I've re-tried your solution with autohotkey workaround (I didn't have any success when I first tried it) and now it works perfect. Thank you very much!!!
Nikos T
gilkbp
Unread post by gilkbp » 16 Apr 2020, 12:22
hello,
someone could confirm me that 64 bits vst plugins are compatibles with HH4 (Kontakt 6 for example) ? Thanks !
NikosT
Unread post by NikosT » 20 Apr 2020, 22:54
Hello @gilkbp, all 64-bit vst plugins are compatible with HH4 on my system. I have NI Komplete and other instruments and effects. They are all work pretty well. I suspect that there isn’t with other plugins.
Nikos T
Users browsing this forum: No registered users and 796 guests
