Export video
noise2sine
there's no option like that. maybe with OBS software
noise2sine
Thanks four your answer ! i will try this . Do you know if in the HH4 it will be possible to have a video rec module ? it would be a dream to be able to record video flux direct into a video file
you can record frame to frame with the player-image for now.
we are working on a a realtime encoder.
noise2sine
thanks that sound amazing ! do you have any time estimation for that ?
That's great. If it will be possible to utilize hardware accelerated encoding like NVENC or Intel Quick Sync Video, it should have minimal impact on performance.
we use ffmpeg library for that, it does a good job and manage hardware acceleration itself.
Users browsing this forum: Bing [Bot] and 243 guests
