master/send channel?
there is a soft clipping option down in the audio setting menu
- x.iso
when you do this via Device patch, you could overwrite default device patch and have this limiter there all the time in any workspace. this can also be used to add some UI elements/controls that you may want to have all the time as well, by placing stuff in this patch and assigning to display necessary components where you want them to be.
Very useful to edit the audio out device. I added a MONO switch like that.
Simon.
Simon.
