mixeur
Hello. I don't think so. But in hh4 maybe. ..
It's kinda possible to do with typical Array/Step module, at least there was a key combination that allow adjusting all values at once, but not selectively. If that's ok, then you could wire it to rack setting module in a poly container:
you could also make separate array for VU display and feed it's bitmap out as background for mixer, add buttons for solo/mute and so on. then make that mixer display in toolbox.
just checked, Ctrl+Shift+Drag works for values inversion, 0 values stay at 0, the rest values would rotate like a wave around 0 value. Shift+Drag offsets values horizontally, Ctrl+click/drag resets values.
If you need to adjust specific selected faders, then it also should be possible, but that would be a bit more complicated patch. and you would use switches to select faders
Thank you x.iso. But if I well understand, the faders are linked together in a fixed manner. Am I right? Or I'd like to be able to link temporarily some faders, and not always the same.
in array they're just side-by-side and not linked. realistically you could make a patch with a row of switches under each fader in array, and a side-fader for relative value change on selected faders. As I've said it's a bit more complicated since you need to make sure to block loopbacks when either of the faders is in use.
Ok I think I understand. Thank you for your help!
Users browsing this forum: Google [Bot] and 558 guests
