Sharing a Usine project to play with
digisense
Unread post by digisense » 01 Feb 2019, 00:11
Hi all,
I am sharing a USINE Hollyhock v3 project with 1.2 Go of free sounds (under creative commons) created for the project called Mixage Fou.
The idea is to create a sound creation of 80 seconds out of these sounds only (transformations allowed).
There are some good partners that come with the project (ie : Nagra, Genelec, Flux::, Ircam, GRM Tools, Merging... ANNNNNNND Sensomusic !)
It is not a classic contest : each partner will listen to all creations individually and they will retribuate their own favourite with a prize (no jury concertation)
Sensomusic's prize is 2 licences of USINE Hollyhock v3
All you have to do is download the project here (direct link) :
http://www.mixagefou.com/spip.php?article214
And upload at http://www.mixagefou.com when you are ready before march 21
I am staying here if you want more details
Happy creation !
digisense
Unread post by digisense » 01 Feb 2019, 19:25
You can use hardware sampler with outboard gear or go software only or a mix... The idea is to push creativity forward out of a selection of dedicated sounds.
Be carefull of the max duration limited to 80 seconds : it is not that easy... ;)
artkax
Unread post by artkax » 06 Feb 2019, 23:26
Bonsoir, doit-on utiliser tous les samples ?
Unread post by oli_lab » 07 Feb 2019, 17:14
un ou plusieurs samples, mais rien qui ne soit pas dans la banque
digisense
Unread post by digisense » 15 Feb 2019, 00:49
oli_lab wrote:un ou plusieurs samples, mais rien qui ne soit pas dans la banque
That's it thanks oli_lab ;)
You can listen to the sound bank in the project now from web player here :
http://www.mixagefou.com/spip.php?article268
I have included an option to download each separate sound in full quality (24bit 48kHz)
Hope these sounds will inspire you
Users browsing this forum: No registered users and 269 guests
