veeseevstrack users ?
foxxb
Unread post by foxxb » 26 Dec 2018, 17:57
I have a little bug with veeseevstrack, the plugin itself works fine, but I have to click a little bit above a knob or a button to make it move, the same to load the modules, it's nothing but is this from veeseevstrack or hollyhock ?
x.iso
Unread post by x.iso » 26 Dec 2018, 18:14
Maybe DPI scaling doesn't work properly?
foxxb
Unread post by foxxb » 26 Dec 2018, 23:05
So how can I fix this, my OS is win 10, it's the only plug that do such thing, I'll report this to veeseevstrack developpers this could help some hollyhock/vcvrack users
x.iso
Unread post by x.iso » 26 Dec 2018, 23:09
Try opening Usine.exe Properties, then Compatibility tab and there you can disable DPI scaling or alter it. See if that helps.
foxxb
Unread post by foxxb » 27 Dec 2018, 13:53
I've tried all possibilites in DPI scaling but the problem is stil the same, thank you
x.iso
Unread post by x.iso » 27 Dec 2018, 15:47
I've checked it out and there seems to be a problem with VST where it displaces itself from the top and leaves a blank space, but if you resize the window from the top (to trim that blank space) everything aligns as it should be.
foxxb
Unread post by foxxb » 27 Dec 2018, 18:27
For me there's a space on the top but it's black and when i resize the window it's inverted, I got to click under the knob :/
thanks for help
x.iso
Unread post by x.iso » 27 Dec 2018, 18:44
Well, if you pull top too much down, then displacement is inverted indeed, you just need to lineup UI so that top row icons start just after Usine's VST options header (with preset save/load and switch). It's strange indeed, maybe it's a bug that can be fixed on Usine side.
foxxb
Unread post by foxxb » 27 Dec 2018, 19:46
It works !! i just resized the black space down step by step instead of one time, thankx x.iso
Users browsing this forum: No registered users and 246 guests
