veeseevstrack users ?
Maybe DPI scaling doesn't work properly?
So how can I fix this, my OS is win 10, it's the only plug that do such thing, I'll report this to veeseevstrack developpers this could help some hollyhock/vcvrack users
Try opening Usine.exe Properties, then Compatibility tab and there you can disable DPI scaling or alter it. See if that helps.
I've tried all possibilites in DPI scaling but the problem is stil the same, thank you
I've checked it out and there seems to be a problem with VST where it displaces itself from the top and leaves a blank space, but if you resize the window from the top (to trim that blank space) everything aligns as it should be.
For me there's a space on the top but it's black and when i resize the window it's inverted, I got to click under the knob :/
thanks for help
thanks for help
Well, if you pull top too much down, then displacement is inverted indeed, you just need to lineup UI so that top row icons start just after Usine's VST options header (with preset save/load and switch). It's strange indeed, maybe it's a bug that can be fixed on Usine side.
It works !! i just resized the black space down step by step instead of one time, thankx x.iso
Users browsing this forum: No registered users and 310 guests
