number of presets available in Piano Roll
emiliano
Unread post by emiliano » 01 Dec 2018, 16:22
In the manual, it says you can have up to 32 midi presets in the Piano Roll.
http://www.sensomusic.org/manual/en/mod ... -pianoroll
I can only have access to 8, then things are blocked at preset 8, even if I access the preset inlet directly in the patch.
How do I access the remaining 24 presets?
Unread post by nay-seven » 01 Dec 2018, 17:22
Clic on the Piano roll module in the patch and use the recreate item in the left menu,
now you can choose up to 32 midifiles
emiliano
Unread post by emiliano » 01 Dec 2018, 21:09
Thanks, it works !
Users browsing this forum: No registered users and 54 guests
