HH multicore preformance
Ariajazz
Unread post by Ariajazz » 12 Oct 2018, 20:59
The question is simple. How does HH3 takes advantage multicore processing?. In other words, How it distributes the workload through the different cores of a CPu, in this case an AMD Ryzen 3 2200g ( 3.5 Ghz. 4 cores).
Thanks.
x.iso
Unread post by x.iso » 12 Oct 2018, 21:29
I would assume that any threads that are not in use are used by modules when needed, so it should be avoiding queues as much as possible. but with VST's it only depends on developer of said VST.
Unread post by sm_jamieson » 13 Oct 2018, 12:12
There is info about the threading in the PDF manual.
I think each rack is a separate thread at the very least. But it probably uses threads more than this,
since you can select the number of threads to use.
Maybe its the OS (e.g Windows) that spreads the theads across the cores.
I'm sure Senso could give us more details.
Perhaps the CPU monitor could be changed to show information about core usage ?
Simon.
Unread post by nay-seven » 13 Oct 2018, 12:20
Find more info in the manual here:
cpu-consumption
Users browsing this forum: No registered users and 137 guests
