Hi All,
First off I must say Usine is a breath of fresh air in my world, I intend on using it exclusively for my live PA, except I've hit a huge hard brick wall. I purchased a Universal Audio Apollo 8 Thunderbolt interface, and Usine keeps dropping it every couple of minutes. Any time I add a new module, the audio device drops (usine says 'audio device not selected' despite the interface still being listed as the selection). Occasionally I can stop the audio engine, go to 'no audio' then switch it back to 'asio' and it will work again, but only for about 2 minutes, or until I add or edit any modules, then it 'loses' the interface again.
Log dump only ever shows the following line: [1:26:35 PM] [audio] --audioDeviceStopped--
Does anyone here use an Apollo? It's probably the most popular interface on the market right now, so if Usine doesn't work with them at all that might cause a fairly large userbase to be excluded.
Any help VERY GREATLY appreciated!
I <3 hollyhock!
Edit, usine works fine with other interface on this computer, and the apollo works fine with other DAWs
specs:
intel i9 7900x
asus prime x299 deluxe mobo
asus strix gtx1080
32gb G.SKILL TridentZ Series RAM
512gb Samsung 960 Pro SSD
2TB Firecuda Hybrid HDD
UAD Apollo Interface not working - Anyone had luck with UAD + Usine?
- nay-seven
Sadly no Apollo to test, but have you try several Usine block size ? buffer size ?
