Oscilloscope Phase Meter
thomaschamotte
you must precise your question
What's the question again?
Web Designer at Petstreetmall
"We are your pet supplies expert"
thomaschamotte
Yes completely sorry about my last question.
When i’m taking the bitmap video out from an oscilloscope patch and plug it into the bitmap video in Usine Crash.
Is it normal or I must open a ticket and send the log ?
We need a workspace example to test, too many patching possibilities
if you short same I/O, then it would create a problem. perhaps it shouldn't be allowed in first place.
thomaschamotte
here you can find a workspace test and clean.
You need to put a song in the player in the rack 1 start using it.
Workspace "Oscilo test.wkp" : http://www.sensomusic.com/forums/uploads.php
The result depend on the source, try for example to add an oscillator ( noise mode) in one of the audio input
Users browsing this forum: No registered users and 29 guests
