Win x64 - Fullscreen Stuck - Anyone Else?
sephult
Unread post by sephult » 18 Nov 2017, 15:11
I've found that my Fullscreen will never come back out of Fullscreen.
When this happens the color palette stops coming up to.
Anyone with x64 ever notice this? At the moment Senso cannot reproduce.
I'd appreciate if others took a look.
-s
x.iso
Unread post by x.iso » 18 Nov 2017, 20:47
Yes, it happens to me and it was mentioned before. Maybe it happens when you trigger the icon by touch, but it also happened when I used keyboard shortcut.
sephult
Unread post by sephult » 18 Nov 2017, 20:58
Okay great, I've had this for awhile...just seems Senso isn't able to replicate. So I haven't been able to get fixed.
Glad I am not the only crazy :P
-s
Unread post by 23fx23 » 21 Nov 2017, 03:11
it happened to me too but now work as espected, or the ctrl+F or mapped key to the icon do the toggle job. don't know what special thing ive done tho
sephult
Unread post by sephult » 22 Nov 2017, 01:12
Hello!
So I have the fix for this. I reported it the other day, but the solution.
Under settings set full-screen on start-up.
If you restart Usine....
The Full-Screen Toggle now works!
Looks like all you have to do is...do this once and it works regardless if you startup in full-screen anymore
-s
Users browsing this forum: No registered users and 138 guests
