USINE HH3 with sierra
Yes, Usine 3 works with Sierra and High Sierra, simply move the .app on the desktop or in the application folder, run it again
May sorry for the out of topic: will rewire or Link be developed in the future?
Maybe in the future,
Have you try wavtap or soundflower ?
shamanic bicycle
Hi everyone !
Encountering some troubles with HH3 on OSX high sierra, impossible to get an asio on the config panel.
I checked to run HH3 from the desktop but nothing to do, HH3 seems not to find any audio setup.
Since i didn't used usine for 6 months, is there something new to do for getting that audio setup appear in the panel ?
or is it the high sierra compatibility not fine for now ?
Shamanic Bicycle
multiinstrumentiste - improvisation
mac OSX10.13 - interfaces Olilab Midi/Osc - RME FF800
My Vimeo Julien Lachal
There's no Asio on Mac but Core audio
how is your Mac preference in the sound tab ?
shamanic bicycle
Hi Nay-Seven !
Right, no audio core detected in HH3.
However, core audio is working on my mac, i run perfectly logic pro, internal device is running, the rme ff800 & zoom H6 works fine too.
Just HH3 do not find any core audio.
I'm trying to follow this thread : https://forums.developer.apple.com/thread/86582
Shamanic Bicycle
shamanic bicycle
New boot after removing the RogueAmoeba suite has no effect on the core-audio availibily on HH3.
Shamanic Bicycle
ok
can you please try a new fresh dezip and place the Usine.app directly in the application folder ?
shamanic bicycle
done, new fresh dezip (HH146) and placed into app folder, tried in desktop too, same issue, no core audio founded.
Shamanic Bicycle
Ok,first time we have this
Can you send me your log file ( usine/right click/Show Package Contents/logUsine.log)
contact@sensomusic.org
shamanic bicycle
Shamanic Bicycle
ok, thanks ( and don't be sorry, this help us in a way)
This topic was first about Sierra, so i first didn't notice you're talking about High Sierra, but i've made test with 146 and from the folder application, works here.
There's some errrors in the log file, we gone to study this..
shamanic bicycle
I installed my old os10.9 and works fine now, core audio reappears !
Seams to be the high sierra not working perfectly on my computer.
Shamanic Bicycle
ok,
if you re install it again, try to delete /Resources/devices/DeviceDMX_2.0_01.usr-osx32 in the package,
maybe a fix in 0147
maybe a fix in 0147
shamanic bicycle
Ok, i'll do it when coming back to high sierra in few weeks.
Thanks a lot.
Thanks a lot.
Shamanic Bicycle
Users browsing this forum: No registered users and 216 guests
