i'm working with the Matrix Groove Physic.
I have modified the patch with :
- control the gain of any balls
- control the pitch of any balls
- add a LFO for any Pitch of any balls
- And add a LFO to the physics speed of the container.
The visual effects of the powerful Usine's physical engineer works with the sound.
And the balls are dancing with my music. It's beautiful !!
Now i have a problem because since i have changed the size of the container, and mov away the two little grey bars the balls move in a weird comportement.
They don't move correctly because they don't bounce into the borders of the container.
They try to go out the container. It seems like something attract them out off the container.
Do you know how can i fix this mechanical problem ?
Thanks for reading.
How to fix the Matrix Groove Physic ?
Not sure thomaschamotte,
I tried resizing the container and moving the panel image...at the moment mine are pretty solild.
Can you share your patch or maybe a picture to show as well?
-s
-s
thomaschamotte
Hello Sephult,
You can find my patch in the uploader and this is a picture.
thomaschamotte
I have resolved my problem.
In the Groove Physic patch ther is two Panel Shape Visible in the Container.
Those two little rectangle called "4" are in the main page of the patch.
If you move it away to hide them and just let them out of the container, the balls act weirdly. They are not in a good control anymore.
Actually if you delete those two modules Panel Shape from the Groove Physic patch it works.
Down.
Down.
Users browsing this forum: No registered users and 420 guests
