Faders in Racks..color and OSC?
Hi
How do I change the colour of, for example, the MUTE button in a rack? It has no Design Eye available.
Also..I am controlling the faders in a rack with OSC...How do I send OSC from the fader back to Lemur? I tried using a OSC Lister module and connecting it to an OSC Send module but it did not work. Any help please!
thanks
thanks
use a SHIFT+Right clic on the mute switch to display the design tab
have you add a device OSC out in the output of the rack ?
I tried Shift + Click or Right Click and nothing happens..I'm on a Mac?
So I have the OSC Out module in position, I just can't get it to send back to the Lemur..I've put the Port and ip address in but what do I put in the ADDR field?
yes, on mac, Shift pressed + Right Click open the settings panel of the switch and you must now see the eye of the design panel
in the addr you enter the same address your fader send from Lemur, generally something like /Fader1/
have an OSC device in the rack output too ?
be also sure to use 8000 as port number, lemur receive only on this port
Hi
Yes I Shift Right Click and nothing! No change in the Settings panel, no appearance of the Design Eye...very strange
Also I have entered the addr as the same address as the fader in the lemur as you say and nothing happens. Frustrating. (Port is 8000 and I have the OSC Send device in the Rack Output)
Ok, my fault about the design of these objects, you need to be in God mode ( global setup/expert/various/), then you can use the Shift+right click,
About OSC, here the patch i use with the faders of the layout names nexus7 studio combo in Lemur, have you something similar ?
God mode! That's it, thanks.
OSC..I can get feedback to Lemur with e.g. a knob in a patch, using OSC Send....my problem is getting that to happen with a Rack fader, which seems 'inaccessible' somehow. Have you got the Rack faders to feedback to Lemur? Thanks
yes, you can use the Rack module( browser/interface control) this way :
Yeh!!
Thank you for your help Nay-Seven..the Rack Module was the key. Wow Hollyhock seems vast right now....you can do everything in HH it seems!
Andy
Andy
It's very nice but if I add an output in the Rack Module (ex: output to another rack), I can't see it in the patch. Is it accessible?
Thanks a lot !
JF
Thanks a lot !
JF
not sure to understand,
if you connect a fader to the output gain outlet , you'll see it in your patch ?
if you want control a second rack with this gain fader you can add a bus to this outlet ?
Users browsing this forum: No registered users and 397 guests
