about preset management in racks and in workspace
I'd like to learn how to manage the preset manager available at the top of a rack.
I see you can take a snapshot of the modules and plugins contained in the specific rack and get a numbered list to recall.
I can't find how to give each preset a name, is it possible?
Also, is it possible to have a general preset manager ( of the whole workspace I mean) that allows me to load a combination of rack presets in one shot?
Thank you
Thank you
to rename, open the list and use an ALT+Clic on the preset to rename it
for the workspace, right clic on empty zone of your workspace and in the settings panel, activate show preset panel
if you use the module preset manager in a patch change its target to workspace
great!
great possibilities and instructions to work on.
thanks a lot
thanks a lot
thank you for the advice.nay-seven wrote:if you use the module preset manager in a patch change its target to workspace
In this case I'm getting a "W017 not allowed to rename" message.
You need to rename the button in the list, not in the combobox
yep, that's clear now.nay-seven wrote:You need to rename the button in the list, not in the combobox
thanks a lot
Users browsing this forum: No registered users and 403 guests
