about preset management in racks and in workspace
unguitar
Unread post by unguitar » 10 Sep 2017, 18:11
I'd like to learn how to manage the preset manager available at the top of a rack.
I see you can take a snapshot of the modules and plugins contained in the specific rack and get a numbered list to recall.
I can't find how to give each preset a name, is it possible?
Also, is it possible to have a general preset manager ( of the whole workspace I mean) that allows me to load a combination of rack presets in one shot?
Thank you
______________
luca
www.unguitar.com
Unread post by nay-seven » 10 Sep 2017, 19:04
to rename, open the list and use an ALT+Clic on the preset to rename it
for the workspace, right clic on empty zone of your workspace and in the settings panel, activate show preset panel
if you use the module preset manager in a patch change its target to workspace
unguitar
Unread post by unguitar » 10 Sep 2017, 19:28
great!
great possibilities and instructions to work on.
thanks a lot
______________
luca
www.unguitar.com
unguitar
Unread post by unguitar » 10 Sep 2017, 22:34
nay-seven wrote:if you use the module preset manager in a patch change its target to workspace
thank you for the advice.
In this case I'm getting a "W017 not allowed to rename" message.
______________
luca
www.unguitar.com
Unread post by nay-seven » 10 Sep 2017, 22:46
You need to rename the button in the list, not in the combobox
unguitar
Unread post by unguitar » 10 Sep 2017, 22:59
nay-seven wrote:You need to rename the button in the list, not in the combobox
yep, that's clear now.
thanks a lot
______________
luca
www.unguitar.com
Ander
Unread post by Ander » 18 Oct 2018, 04:27
How can I reorder presets?
