I've noticed that Usine won't finish to load if I'm plugged to a LAN without internet connection
If I plug the Internet wire to my router usine would load ok ...
Anyone get the same thing ?
My Lan is something about 10.0.0. etc because of artnet specification (Using an Enttec)
LAN with no internet
- nay-seven
interesting, someone recently have a slow Usine when computer is connected to a wireless network with no internet access. Maybe linked.
We will study this .
gurulogic
Yes, I had discovered the same thing. HH had no problem for the computer connected with cable to the router, but tried with two others connected wirelessly and HH would barely load. One thing maybe to try is to give a static IP? Haven't had any time to check myself yet.
- x.iso
I haven't tried to use HH3 without any network connection, but if there is a connection and sensomusic.org is not accessible for whatever reason (for me the reason is that sensomusic.org is blocked in our country), you get freezes as you try to load anything and HH3 tires to wait for response from server to no avail. I can understand if it happens when you try to update addons or enter login information to activate HH3, but to connect to server for random reasons is questionable.
- nay-seven
to x.iso : In most of the cases, once installed and registered, add-ons downloaded, you don't need any internet connection to work and Usine don't try any connection. Here we talk about using an internal LAN to communicate between several machines.
