Bug in a Subpatch
thomaschamotte
Unread post by thomaschamotte » 17 Aug 2017, 22:23
I think i have a bug in a sub Patch.
I can't pull a strink, add a module, move a modul... i can't do anything.
It's happened in a Groove Physic -> patch -> sub patch 2,3,4,5,6,7,8
The 1 is ok.
Is it a real bug ?
Thanks.
Unread post by nay-seven » 17 Aug 2017, 23:19
No, this is not a bug but a polyphonic sup patch, you make the change in the voice 1, then you use the apply the polyphony button to apply your change to all the voices,
check about sub patch. in the manual.
thomaschamotte
Unread post by thomaschamotte » 17 Aug 2017, 23:20
nay-seven wrote:No, this is not a bug but a polyphonic sup patch, you make the change in the voice 1, then you use the apply the polyphony button to apply your change to all the voices,
Thank You
Users browsing this forum: No registered users and 498 guests
