Stretch a hardware with Usine
thomaschamotte
Unread post by thomaschamotte » 20 Jul 2017, 19:12
Hi Everyone,
In the configuration of my workspace i'm using a JamMan Digitech Stereo with usine.
Manuel : ftp://ftp.digitech.com/pub/PDFs/Manuals ... 0707-B.pdf
Unfortunately the Jamman can't be clocked with Usine because the jamman doesn't have Midi.
But with the Footswitch FS3X ( who is a propriety of Digitech) i can stretch the Jamman in a realtime.
So my solution is to creat the same signal as the Footswitch with Usine.
In the back of the Footswitch we can read : "this device complies with EN55013 and meets the rquirements of CISPR22 as prescribed by ICES 003". I don't know what does it mean and if it's important.
This is the schematic of the footswitch.
The Output i need is the "UP" output 3 as it's explain in the Manual of the Jamman
For know when i just send a metronom signal in the Jamman it doesn't work.
Do you know if i have to create the same electric wiring in a patch ?? And if i have, could you help me to made it ?
Thank you for reading.
Unread post by oli_lab » 23 Jul 2017, 08:08
Hi Thomas,
D1 and D2 are here to have tip and ring drove to the ground when using the "loopUp" switch whithout activating REC and Ring.
you'll need to know the voltage of tip and ring, something between 5 and 9 Volts probably
then you'll have to build something to interface Usine with the JamMan :
use the same schematic as above but replace the mechanical switches by optocouplers
http://www.ebay.com/itm/30-50-100-500-8 ... 3016513203
then you need to communicate from Usine to the JamMan : that can be done with a microcontroller, say we use the Teensy that is easy :
http://www.sensomusic.com/wiki3/doku.ph ... _interface
it will receive midi from Usine via USB and open and close the optocouplers to give orders to the JamMan.
Unread post by nay-seven » 23 Jul 2017, 14:58
just see this link on Facebook today:
http://www.erikoostveen.co.uk/#anchor2
Maybe can do the job ?
thomaschamotte
Unread post by thomaschamotte » 23 Jul 2017, 16:02
Hi Olivar,
Thank you for your answer, it's amazing... I didn't expect this way of reflexion.
Can you tell me if my schematic is correct ?
Unread post by oli_lab » 23 Jul 2017, 16:41
thomaschamotte wrote:Hi Olivar,
http://www.sensomusic.com/forums/upload ... chFS3X.jpg
few errors :
pin numbers for the teensy : :use the digital pins as outputs for example 0,1 & 2
https://www.pjrc.com/teensy/teensyduino.html
use resistor to protect the LED inside the optocouplers : R = 180 Ohms
current in the transistor of the optocoupler should go from 4 to 3 pin
thomaschamotte
Unread post by thomaschamotte » 23 Jul 2017, 16:52
few errors :
http://www.sensomusic.com/forums/upload ... 163557.jpg
Ho,
Thank you so much...
I just have to go to a micro electronic shop and do it ...
I keep you in text and send you some pictures.
thomaschamotte
Unread post by thomaschamotte » 23 Jul 2017, 17:34
few errors :
Ho,
I'm Looking about the price of this adventure.
My built is 55-65$...
Do you think it's a good choice ?
Or do you know some hardware solutions who does exist and cost less than my homemade price ?
Unread post by oli_lab » 23 Jul 2017, 21:30
it is a 8 bit teensy you need : https://www.pjrc.com/store/teensy.html
by directly from PJRC
you need a TRS jack female, not mono
dont forget the 3 180 Ohms resistors
as well as the 2 1N4001 diodes
go to ebay, it is way cheaper
you"ll need solder as well
where abou Canada do you live ? I'm sure you can find a place with geeks with soldering iron !
thomaschamotte
Unread post by thomaschamotte » 23 Jul 2017, 21:33
oli_lab wrote:it is a 8 bit teensy you need : https://www.pjrc.com/store/teensy.html
Thank you so much,
I have to be carful.
I will do my best !!
I'm living in Toronto... i will see around if some geek can help me :)
Tchuss
thomaschamotte
Unread post by thomaschamotte » 23 Jul 2017, 22:01
iococoi wrote:this one looks quite decent..
https://hacklab.to/about
..more here
https://wiki.hackerspaces.org/Toronto
Yes Thank you !
thomaschamotte
Unread post by thomaschamotte » 23 Jul 2017, 23:07
Thank you so much,
Tchuss
I'm Looking for something who could be very interesting.
I bought a ActitioN 8 USB Midi/Jack
This is the Pictures of the Footswitch ActitioN8 and the Short Manual:
https://www.actition.co.uk/
It is a multi functional footswitch very powerful.
It is very easy to use it with usine.
Do You think i can Use directly this footswitch with a Usine Patch to Stretch the Jamman Stereo Digitech ?
Unread post by oli_lab » 23 Jul 2017, 23:21
no !
it is only for communicating from the "action box" towards Usine.
what you need for the jamman is something to communicate from usine towards the jamman.
what you could try is use the grain sampler of Usine instead of the jamman and control it with the action box !
thomaschamotte
Unread post by thomaschamotte » 23 Jul 2017, 23:24
oli_lab wrote:no !
Ok, i got it.
I already buy the Teensy 8Bits to PJRC.
Thank you a lot for your answers and your Time Oli_Lab.
thomaschamotte
Unread post by thomaschamotte » 11 Aug 2017, 22:19
oli_lab wrote:no !
Ok, i got it.
Hi Oli_Lab,
I have almost all the components to build my special switch we talked about it.
I called it TeenyCouplers because i use the Teensy with optocouplers :)
As you know i'm living in Toronto and here there are any shops who have the optocouplers you advised me.
So on Ebay i bought 10 pieces of "PC817 PC817C EL817 817 Optocoupler SHARP DIP-4" but the delivery is so long 3 or 4 weeks...
So i found this website http://ca.mouser.com/search/refine.aspx?N=11624526 who can send me the optocouplers quickly.
The thing is, there is so many optocouplers i don't know witch one choose.
Can you help me for these last step ?
thomaschamotte
Unread post by thomaschamotte » 19 Aug 2017, 06:41
oli_lab wrote:no !
Ok, i got it.
Hi Oli_Lab,
I have made a new Topic from our conversation to the way to patch the Tennsy in Usine.
New Topic : http://www.sensomusic.org/forums/viewtopic.php?id=5843
In conclusion i will certainly make an article about it.
Peace.
Users browsing this forum: No registered users and 420 guests
