Problem installing demo on win7
Welcome unguitar,
Generally, it's better to inactivate anti virus to install, some are a bit sensible, can you precise about authorization issues ? You can also contact us on contact@sensomusic.org for a direct support
I'm on Windows 10. Generally when first unpacking and running windows defender will complain, and you just run anyway. Most antivirus will let you add exceptions wen running things. You could start there by checking your antivirus options. I'm not sure about the authorization issues though. Can you explain?
Sorry, I've been diving into it.
Anyhow, all runs well if I open Usine by clicking on the Usine app file which I find in the BIN folder.
ok, good news !
sorry for the dumb question: which is the limit of the demo version?
You can save and load your work on this version, no worries,
only a message time to time to remind you Usine is not free
yes, this is a great way to allow a deep test, which I'm doing and with very positive results!
Big important steps ahead you've done, this latest version looks very very well laid out and functional.
Hats off
Hats off
Yes there is so many subtle improvements and additions in HH3 that make the sum of all the parts a very big evolution. Without a detailed change log available it is a good idea for even a seasoned Usine veteran to read over the manual to see what is new.
Thanks guys, be the sure the team and the community appreciate your words !
Yes there is soo much different, and such improvement in stability...yes it's hard to explain every new feature or change.
Maybe I can put together a list from what I know.
Very much appreciated gurulogic, I know everyone appreciates as nay has said.
-s
-s
Users browsing this forum: Bing [Bot] and 209 guests
