midi chords vst doesnt work in Usine
seamus
Unread post by seamus » 07 May 2013, 07:49
This vst midi chords (insert PIz) is somehow not working correctly in Usine.
It works fine in Reaper but not in Usine. :(
Anyone have any ideas why this plug wouldnt work fine in Usine but works in Reaper?
Unread post by senso » 07 May 2013, 18:24
hello Seamus,
Be patient it will work on Hollyhock...:)
r.erorr
Unread post by r.erorr » 07 May 2013, 23:32
:) Hollyhock Hollyhock
seamus
Unread post by seamus » 04 Jun 2013, 20:38
It does now indeed work with hollyhock. Bravo!
mattmarantz
Unread post by mattmarantz » 06 Jul 2017, 11:05
Hi Seamus.
I am wondering if anyone can tell me how to hook up Insert Piz MIDI Chords correctly in Usine HH3. How do you set it up? I have MIDIChords working great in Reaper, but I am baffled about how to set it up in HH3. Thanks. Please let me know, if you can!
Best,
Matt
Ah, simultaneously as I have asked this question, I received this from Sensomusic:
"To send MIDI to several racks or patch you can use MIDI buses, you create a wire from the midi out of the plug-in and choose send to MIDI bus
then in an other rack from the input you select Get from existing MIDI bus"
Cheers,
M
mattmarantz
Unread post by mattmarantz » 06 Jul 2017, 11:14
And it worked! Thank you very much.
Cheers,
Matt
Users browsing this forum: No registered users and 358 guests
