Problem installing demo on win7
unguitar
Unread post by unguitar » 01 Jul 2017, 00:48
hi,
I'm encountering authorization and antivirus issues after downloading Usine Hollyhock win64 3.0.132
Anyone else?
thanks,
Luca
______________
luca
www.unguitar.com
Unread post by nay-seven » 01 Jul 2017, 08:50
Welcome unguitar,
Generally, it's better to inactivate anti virus to install, some are a bit sensible, can you precise about authorization issues ? You can also contact us on contact@sensomusic.org for a direct support
sephult
Unread post by sephult » 02 Jul 2017, 15:06
I'm on Windows 10. Generally when first unpacking and running windows defender will complain, and you just run anyway. Most antivirus will let you add exceptions wen running things. You could start there by checking your antivirus options. I'm not sure about the authorization issues though. Can you explain?
unguitar
Unread post by unguitar » 08 Jul 2017, 14:23
Sorry, I've been diving into it.
Anyhow, all runs well if I open Usine by clicking on the Usine app file which I find in the BIN folder.
______________
luca
www.unguitar.com
Unread post by nay-seven » 08 Jul 2017, 15:13
ok, good news !
unguitar
Unread post by unguitar » 10 Jul 2017, 23:27
sorry for the dumb question: which is the limit of the demo version?
______________
luca
www.unguitar.com
Unread post by nay-seven » 11 Jul 2017, 00:01
You can save and load your work on this version, no worries,
only a message time to time to remind you Usine is not free ;-)
unguitar
Unread post by unguitar » 11 Jul 2017, 00:13
yes, this is a great way to allow a deep test, which I'm doing and with very positive results!
Big important steps ahead you've done, this latest version looks very very well laid out and functional.
Hats off
______________
luca
www.unguitar.com
gurulogic
Unread post by gurulogic » 11 Jul 2017, 07:54
Yes there is so many subtle improvements and additions in HH3 that make the sum of all the parts a very big evolution. Without a detailed change log available it is a good idea for even a seasoned Usine veteran to read over the manual to see what is new.
Unread post by nay-seven » 11 Jul 2017, 08:10
Thanks guys, be the sure the team and the community appreciate your words !
sephult
Unread post by sephult » 11 Jul 2017, 11:41
Yes there is soo much different, and such improvement in stability...yes it's hard to explain every new feature or change.
Maybe I can put together a list from what I know.
Very much appreciated gurulogic, I know everyone appreciates as nay has said.
-s
Users browsing this forum: No registered users and 315 guests
