anyone using joysticks with usine?
So..Im really happy i could tweak a hid 3d mouse "space navigator" so it could be seen in usine as a joystick and get the usable motion datas.
it's a 6 degrees device: Translation X, Y, Z, and Rotation X, Y , Z.
I do see all datas moving on the joystick module, spread to the 6 axis, except for one wich is supposed to be the " HIDJoystick_Ry"
supposed to be on axis-5 on the module.
maybe it's an error from my side, or someting to tweak in windows, just wanted to know if somebody already used this 'axis-5' and check its not coming from usine.
I'm not but it sounds like an awesome idea!
yes there are cool things to do i think
it was much easier than i thought, i was about to dive in hard stuff like attempting to make a module with their sdk, then i just discovered by just editing an xml can convert the HID datas to virtual joystick datas, and then usine is able to read them out of the box via the joystick module.
just a quick test of Z axis for pressure:
https://drive.google.com/open?id=0B0VUy ... zF2RzRxY2c
that is very intersting indeed !23fx23 wrote:yes there are cool things to do i think![]()
...by just editing an xml can convert the HID datas to virtual joystick datas, and then usine is able to read them out of the box via the joystick module.
would you share the hack ?
cheers !
yes, but think i havn't been very clear sry, note it's specific to 3dconnexion mices devices, because their driver kinda make a virtual keyboard/mouse/joystick new hid device , and a per app xml hidden that watch when an .exe is launched and creates some binds between their hid and the virtual driver. in it's not a trick working for all HID devices sadly..
but in case some go for those kind of mice, the xml are located in
C:UsersUserNameAppDataRoaming3Dconnexion3DxWareCfg
and mine for usine looks like this:
Code: Select all
<?xml version="1.0" encoding="UTF-8"?>
<AppCfg Default="false" xmlns="" CfgFormatVersion="1.2" ThisFileVersion="1.4">
<AppInfo>
<Signature>
<Name>Usine.exe</Name>
<ExecutableName>Usine.exe</ExecutableName>
<Transport>KMJ</Transport>
</Signature>
<Options />
</AppInfo>
<CfgProperties>
<InheritsFrom>STR_DEFAULT_KMJ</InheritsFrom>
</CfgProperties>
<Settings>
<OverallScale>0.34</OverallScale>
<ResponseCurve>1.00</ResponseCurve>
</Settings>
<Devices>
<Device>
<Name>Standard 3D Mouse</Name>
<VendorID>0</VendorID>
<ProductID>0</ProductID>
<InheritsFrom>Standard 3D Mouse</InheritsFrom>
<Axis>
<Enabled>true</Enabled>
<Input>
<ActionID>HIDMultiAxis_X</ActionID>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDJoystick_X</ActionID>
</Output>
</Axis>
<Axis>
<Input>
<ActionID>HIDMultiAxis_Y</ActionID>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDJoystick_Y</ActionID>
</Output>
</Axis>
<Axis>
<Input>
<ActionID>HIDMultiAxis_Z</ActionID>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDJoystick_Z</ActionID>
</Output>
</Axis>
<Axis>
<Input>
<ActionID>HIDMultiAxis_Rx</ActionID>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDJoystick_Rx</ActionID>
<Reversed>false</Reversed>
</Output>
</Axis>
<Axis>
<Input>
<ActionID>HIDMultiAxis_Ry</ActionID>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDJoystick_Ry</ActionID>
</Output>
</Axis>
<Axis>
<Input>
<ActionID>HIDMultiAxis_Rz</ActionID>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDJoystick_Rz</ActionID>
</Output>
</Axis>
</Device>
<Device>
<Name>SpaceNavigator</Name>
<VendorID>46d</VendorID>
<ProductID>c626</ProductID>
<ButtonBank Default="true">
<Name>STR_DEFAULT_BUTTONBANK</Name>
<ID>Default</ID>
<Button>
<Input>
<ActionID>HIDButton_1</ActionID>
</Input>
<Output>
<ActionID>HIDJoystick_1</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_2</ActionID>
</Input>
<Output>
<ActionID>HIDJoystick_2</ActionID>
</Output>
</Button>
</ButtonBank>
</Device>
</Devices>
</AppCfg>Yeah I just picked up a joystick as well and was looking into doing this sometime in the near future too.
Very awesome, thanks!
-s
-s
Users browsing this forum: No registered users and 154 guests
