Mac - can't click anything
djaychela
Unread post by djaychela » 09 Jun 2017, 21:42
I've used Hollyhock on my Windows PC for a while, but have just bought a Mac and installed it on there. And while it runs... I can't click anything - whenever I move my mouse over an icon or button, it momentarily 'lights up' and then goes back to how it was before the mouse was over it. I can't click anything to get anything working. I know that hollyhock is sometimes a little 'special' when it comes to the UI, but this is a whole new level - I can't use it at all at the moment.
Any help? It's a macbook air running Sierra (10.12.5). Everything else works OK on it - I can't think of any reason why this would be the case. And I can't even access anything in hollyhock to change any settings, even if I thought there was one that would help!
Unread post by nay-seven » 09 Jun 2017, 22:01
I can confirm you Usine works on Sierra 10.12.5
Sometimes there's some writing rights issues on Sierra, where have you unzip Usine ? can you try on the desktop and test?
djaychela
Unread post by djaychela » 09 Jun 2017, 22:24
Hi
Thanks - I've tried again with it on the desktop, but the same issue happens - Nothing seems to work after an initial few seconds (which allowed me to open the project in this video), and then clicking or not clicking when hovering over an icon seems to make no difference. I've done a quick video (it's unlisted on youtube) to show it - you can hear me clicking and some of the icons 'light up' but Im not seeing everything I think I should be, and then in the second half just moving the mouse pointer over that position has multiple icons lighting up. At this point I couldn't do anything with any of the icons in the project or in Hollyhock - the only thing I could do was quit (and that wasn't via keyboard shortcut which doesn't work, only via the menu).
https://www.youtube.com/watch?v=jlPtAZ2ykV4
Unread post by nay-seven » 09 Jun 2017, 23:25
Thanks for the video,
yes, really strange, i suppose you use the trackpad or it's an external mouse? ( if not can you try an external one ?)
anyway can you send me your log file at contact@sensomusic.org please
right clic on the .app and choose something similar to display the content , you'll see a file named LogUsine.log
djaychela
Unread post by djaychela » 10 Jun 2017, 09:15
Hi
I've just sent two log files - hopefully they will help work out what's happening!
Darren
Unread post by cmodica » 12 Jun 2017, 10:30
Very strange.
i run Hollyhock 2.0 090 with Mac OS Sierra 10.12.5 for a long time without any problem.
Users browsing this forum: Google [Bot] and 1234 guests
