pre-listen sound files
Akis
Unread post by Akis » 18 Jan 2017, 11:11
Is there a way to pre listen sound files in an other audio bus than the main audio output?
And In the list view of a sample player, how can I put in the list some files at the same time? I think I do it yet but I don't succeed anymore, so I have to put the files one by one in the list.
iococoi
Unread post by iococoi » 19 Jan 2017, 08:02
hi,
i dunno about the pre-listen thing, but to add more files at a time, just shift/ctrl-select more files in the add file dialog.
Akis
Unread post by Akis » 19 Jan 2017, 10:33
Thanks !
I thing I've forgotten this way as I more often load files by dragging them, but is it not possible by dragging?
otherwise the add files way is good too.
iococoi
Unread post by iococoi » 19 Jan 2017, 10:56
i guess drag&drop just works for/from the internal browser and not from the os level..at least on my win10 system.
http://www.sensomusic.org/wiki3/doku.ph ... _drag_drop
Akis
Unread post by Akis » 23 Jan 2017, 10:41
By the internal browser I can just drag and drop them one by one here as with the browser os, I'm also on windows 10 system.
Users browsing this forum: No registered users and 179 guests
