Make Usine remember the screen position of VST plugins when recalled
Ariajazz
Unread post by Ariajazz » 15 Nov 2016, 22:12
Hi folks.
I need to make USINE STAGE v5.8 to store or remember the exact screen position of plugin GUIs when recalled.The idea is to automate some mouse movements and clicks for many plugin's functions that cannot be controlled in any other way (midi, parameters, etc) but by mouse.
Saving the patch and/or workspace don't work. It opens the vst's GUI's kind of randomly, no matter if I reposition the GUIs and save patch and workspace, it does not store the new position. It happens more noticeable with several instances of Amplitube 3. BTW I read an old post from 2009 abut this same issue. Senso responded that the problem was going to be solved in the next release. Mine is 5.80 which I believe it was released on 2011.
Any of you have an idea on how to achieve this?... Thanks a lot guys...
Ariajazz
Unread post by Ariajazz » 19 Nov 2016, 21:48
No one has a clue?
La Tenaille
Unread post by La Tenaille » 19 Nov 2016, 23:09
I don't use your Usine version but under Hollyhock the window position is not random, it appears under the mouse cursor.
Have you tried using a popup window ? You can force its position using module position x/y pins.
Ariajazz
Unread post by Ariajazz » 21 Nov 2016, 02:46
Thanks La Tenaille. Popup window solved the issue. In Usine stage popup windows are always on top and centered. How didn't I think about it? Maybe because I haven't use popup windows before. Thanks again.
Users browsing this forum: No registered users and 277 guests
