Stomp box question
EspressoPianist
Unread post by EspressoPianist » 19 Sep 2016, 23:24
Could someone please advise on something which is probably very basic....
I'm trying to set up a stomp box (Tech21 MidiMouse) to run through a list of presets on a MacBook Pro in order. I've set the preset numbers to the stomp box numbers using MidiLearn, and all looks well. However when I try to run through the presets in order the very first preset (and only that one) takes the whole screen into MidiLearn mode. I can use all of the presets perfectly except the very first.
Any thoughts?
Thanks in advance for helping.
sephult
Unread post by sephult » 19 Sep 2016, 23:46
You probably trained that first preset on the stomp box to trigger the MIDI Learn Mode. You can use Midi to access the different functions of Usine.
Right Click the MIDI Learn Button to bring up the settings panel and you should be able to see what is triggering it.
-s
EspressoPianist
Unread post by EspressoPianist » 20 Sep 2016, 11:47
Thanks, that's very helpful. I'll give it a try and report back.
sephult
Unread post by sephult » 20 Sep 2016, 12:26
Awesome!
If you need anymore help, let me know and I'll try to respond as best I can.
-s
Users browsing this forum: Bing [Bot] and 248 guests
