midi channel switcher VST?
Don't know what you need exactly, but you can built it in Usine ?
Here an example to switch between 2 channels:
Hi:
Looks interesting.
Can you explain the logic behind your design so that I can reproduce it?
Thanks.
Looks interesting.
Thanks.
I don't know your needs, but it's a small example
in your Midi flow, you can add this MIDI transform module, then you connect a switch to the channel inlet
here i imagine you want to switch between channel 1 and 2, so my switch have this 2 values, as ON/OFFvalue and as ON/OFF caption
you can then add a midi learn to this switch to alternate between this 2 channels
Can the switch module be controlled by an external controller(ex:Stealthpedal) ?
yes, as far as this pedal send Midi messages ( you can also add a external dual footswitch to this one right ? )
Yes, I can add a dual switch and also a volume pedal. All three pedals (dual switch, stealth and volume) are capable of midi messages.
Hi:
I reproduced the switch. Can you give me some advice on how to setup it for use?
http://www.sensomusic.com/forums/upload ... switch.jpg
i crop your picture ( was 4000by3000 pixels...
here your patch:
in your version you switch from 0 to 1 , this mean channel 0 ( all channel in Midi language) to channel 1
so you need to change the ON value to 2 and OFF value to 1 for this switch
Now, about the use, you need to add your midi device on the rack input and i suppose a plugin after this patch ? i need more precision on what you want to achieve..
here your patch:
btw, next time, this kind of question have their place in the patching forum please
Are you able to move this discussion to the patch forum?
I would like to continue with this discussion until the problem is solved.
dont worry, we can continue this discussion, just think about it next time
That midi switch patch works like a charm.
I used the patch on both Sample Tank 3 and Xpand!2 without a hitch.
Thanks for the help.
Users browsing this forum: No registered users and 216 guests
