Behringer 1010 pedal button indicator changes
Zoot
Unread post by Zoot » 01 Jan 2008, 13:24
Appologies if this has been asked before...
I'm trying to use a Behringer 1010 pedal with Usine to make a headless workstationgig box. The Behringer pedal will be used to record piano rolls, change effects and vst instruments.
Does anyone know if it is possible to change the status of the 1010 stomp button leds or activate another button from within Usine using a midi or sysex send?
Also is it possible to get Usine to trigger the "value1 and 2" LED's on the 1010?
The Behringer seems to remember the last button pressed, it would be usefull to be able to turn the button led off or active another one after a Usine function has completed.
Thanks All
Zoot
ian_ep
Unread post by ian_ep » 02 Jan 2008, 07:30
I don't think this is possible with the FCB1010. As you noted it just 'remembers' the last button pressed. It would be a lot more expensive if it could receive toggle state info via midi. There are pedals that can do this but they cost 5 or 10 times as much!
Ian
goyya76
Unread post by goyya76 » 02 Jan 2008, 23:35
hi guys - Zoot, have a look at http://launch.groups.yahoo.com/group/bc2000 -
there's a guy who disassembled the FCB1010 firmware and reprogrammed it adding more functions - i don't know more cos i got into the group has a bcr+bcf owner, but maybe there's something that could help!
Ciao,
Goyya
Users browsing this forum: No registered users and 61 guests
