Add multiple outputs to any AU or VST plugin.
jonathanpontier
Unread post by jonathanpontier » 13 Nov 2015, 00:55
Hi all charitable Usine users,
I'm brand new in Usine, and I still can't manage to create new outputs from Reaktor or Kontakt in the patch edit window of Usine.
That means, all my existeing outputs in these plugs are greyed and "not connected", as they perfectly work in standalone mode or in any seq host... Can someone help ?
I'm looking forward to read multiple midi files at once in the same patches (sending MIDI data thru several MIDI channels in Reaktor). Before getting to that, I'd simply like to get my patchnig right with a handful of outputs....
Thanks in advance !
Jon
Unread post by nay-seven » 13 Nov 2015, 10:14
What you need to check :
if we talk about Reaktor 5, choose the 16 outputs version of the plugin, Reaktor 6 has only 1 version
if you need physical outputs for your soundcard, be sure to activate them in the setup/audio tab
now drag a wire from the audio outlets of the plugin, can you create a new audio out modules ? (will be named audio 3, audio 4)
jonathanpontier
Unread post by jonathanpontier » 14 Nov 2015, 14:02
Thanks a lot ; the 16 out reaktor vesrion does not appear though, even after rescan and although it appears in other softs...I will try to copy the vst file in my user and scan in the 3d folder area in Usine to see how it works :)
jonathanpontier
Unread post by jonathanpontier » 16 Nov 2015, 17:26
Hi Nay and all of you nie usine users. The Reaktor 5 instance appears in other softs such as Logic, Reaper and all...so it might be a problem of system compatibility (a friend suggestetd that my 2008 2,8 Ghz macbookpro, recustomized with SSD and 8 Go RAM, might be a problem...) but I am not sure about that since reaktor appears in other softs. Cheers.
sephult
Unread post by sephult » 16 Nov 2015, 17:51
Hi jonathan,
I am running both Reaktor 5 and Reaktor 6 and have visible 16-outputs from both. As nay had said for Reaktor 5 you must have a separate VST instance (it will say Reaktor5 16-out). In your plugins you will have multiple VST for Reaktor 5, however Reaktor 6 is only one VST.
I am using Windows, 64-bit version of Usine. (Make sure you are also using the correct 32 or 64 bit plugins for your Usine version)
For the 16-outputs you must enter the patch edit screen and wire the additional outputs in order to see them in the Rack output VU Meter section.
-s
DruMunkey
Unread post by DruMunkey » 18 Feb 2016, 22:08
Jonathan, did you get this to work?
Users browsing this forum: No registered users and 292 guests
