Hey the audio engine is one when I load
joojoo1234
Unread post by joojoo1234 » 29 Nov 2007, 17:49
and the piece starts I want the wkp to load with the audio engine off and the sequencer unlit - whats the method to insure this?
joojoo1234
Unread post by joojoo1234 » 29 Nov 2007, 17:50
okay let me do that again - the audio engine is lit as well as the play button on file load - I want the opposite. always
Unread post by senso » 29 Nov 2007, 20:08
the on/off engine button stays in the state you leave it before the loading of workspace.
When you load a patch, it doesn't affect the play button; Allows you to add patches in your session without turn the engine off.
Do you want to change this ?
joojoo1234
Unread post by joojoo1234 » 29 Nov 2007, 20:56
Yes
joojoo1234
Unread post by joojoo1234 » 29 Nov 2007, 20:58
I still want to launch samples but as far as loading patches in the sense I think you mean I won't do that.
Unread post by senso » 29 Nov 2007, 21:48
I' not sure I understand why you want to change and what you propose instead!!!!
joojoo1234
Unread post by joojoo1234 » 30 Nov 2007, 00:07
Okay, well my situation is I want to load a wkp and I don't want the sequencer to start automatically and I don't want the audio engine on. Just tell me how to avoid this please. Thanks.
joojoo1234
Unread post by joojoo1234 » 30 Nov 2007, 00:08
I have actually learned a ton about this in a matter of a few days bear with me.
