Looking for a Drum rack module
noise2sine
Unread post by noise2sine » 31 Aug 2015, 17:36
I think i saw a drum rack module in Hollyhock close to the one proposed by ableton Live and unfortunatly i can't find it again, where can i find it ???
sephult
Unread post by sephult » 01 Sep 2015, 07:09
Look under Library/Pads/Sixteen Pads.
Is this what you are talking about?
-s
noise2sine
Unread post by noise2sine » 01 Sep 2015, 10:36
Thanks, the pad kontrol is more what i was looking for.Anyway i think it can be cool to have a little patch for managing drum kits.My dream is to have one small like the drum rack from Ableton plus a delay...All in one
Unread post by nay-seven » 01 Sep 2015, 16:04
Have you test the new Midi sampler ? you can create your own banks and it's really light.
you can of course start from the pad kontrol and add a sub patch delay and create all modifications you need, the community can help you on this.
noise2sine
Unread post by noise2sine » 02 Sep 2015, 14:02
Thanks, yes the Midi sampler is perfect, but the others too ;).
Users browsing this forum: No registered users and 544 guests
