External midi Error:Internal in BufferSwitchTimeinfo
raintalk
Unread post by raintalk » 29 Nov 2007, 16:35
I'm trying to use midi from an external app to drive Usine 3.340
I really wanted to get the external sync and MMC going, but it didn't seem to work and Usine reports: Error:Internal in BufferSwitchTimeinfo
I turned off the sync/start in the external appplication and just had it send midi but I still get the same.
Are these errors documented? Is there someplace I should look?
thanks,
Unread post by senso » 29 Nov 2007, 20:14
Normally the external synchro with MMC and MTC works fine.
I'll test it again.
Please send the bugs reports by mail and join your LogUsine.log file at contact@sensomusic.com
