Locate/Find in Patch - HH2
CleverConQueso
Unread post by CleverConQueso » 14 Aug 2015, 22:50
Do I recall correctly that there used to be a right-click option to find a knob or fader in the patch by clicking on it in the control panel? I can't find that now. Can someone help my eyes out and point me to it?
CCQ
sephult
Unread post by sephult » 15 Aug 2015, 01:01
When you select an object in the interface, the left side context menu will display a find in patch.
The module will now show in a brighter orange, making it easier to find.
I love this feature and use all the time.
Sometimes thought I wish there was a reverse option to find the interface object by selecting the module.
-s
CleverConQueso
Unread post by CleverConQueso » 15 Aug 2015, 18:35
Ahhhhhhhhhh..... Thanks. I get it now. The stuff that used to be right-click is now over on that menu so that you can use it on the touch screen. Thank you so much.
Users browsing this forum: No registered users and 139 guests
