MIDI seems to "break" when I put two Piano rolls in series?
loneboat
Unread post by loneboat » 18 May 2015, 20:17
See screenshot below. I'm learning about the "Midi Piano Roll" from the library. If I add one and put a VST after it, it works just fine. If I try to "chain" two piano rolls together, then it SORT OF works, but some notes get stuck on. As though some of the NOTE OFF messages are being lost. Is there a better way to do this? I want to send two piano rolls to the same VST.
Thanks!
shawnb
Unread post by shawnb » 18 May 2015, 22:12
Have you tried putting them in parallel?
loneboat
Unread post by loneboat » 18 May 2015, 23:23
No, I haven't. How do I put patches in parallel? Would that involve an additional rack? Or can you do parallel patches in a single rack? (If it's an additional rack, I don't know how I would go about getting the extra rack's output back into the VST)
Thanks so much for your reply! :-)
Unread post by nay-seven » 18 May 2015, 23:39
you can create sub patches and link them in parallel
here an example
