The Browser Window is empty
joojoo1234
Unread post by joojoo1234 » 20 Nov 2007, 16:51
even after rescanning? Help - using Usine got it going fast!
Unread post by senso » 20 Nov 2007, 19:01
which browser?
modules, lib, vst, audio?
check you paths in the setup/interface?
joojoo1234
Unread post by joojoo1234 » 20 Nov 2007, 19:22
well I installed everything and my vst's are not showing up. And they have been installed and rescanned with the correct directory - this happened when I dragged a patch with windows into the demo folder... I also renamed the demo folder... is that bad?
Unread post by senso » 20 Nov 2007, 19:27
Yes rename the demo folder or any folder in the usine directory is not allowed!!!
joojoo1234
Unread post by joojoo1234 » 20 Nov 2007, 19:44
I'm good now.
joojoo1234
Unread post by joojoo1234 » 21 Nov 2007, 02:57
I have finished my first piece in Usine. I like.
Unread post by senso » 21 Nov 2007, 08:22
cool!
