Multi input recording
theotteryears
Unread post by theotteryears » 27 Mar 2015, 12:23
Hello and apologies if this is a very basic question... I have recently bought HH2 and haven't had chance to try it out much yet.
I was wondering if there was a was to easily record 4 inputs at once into a sampler or looper or something (i want to record myself playing drums using 4 mics)?
Thanks in advance and sorry if this is really easy to accomplish!
Chris
Question
Unread post by Question » 27 Mar 2015, 12:29
Using a sampler module with 4 inputs maybe : )
It asks you the required number of inputs when you put it in a patch.
As long as you have 4 or more input sound card that would be no problem.
Q
ceasless
Unread post by ceasless » 27 Mar 2015, 12:45
A few different ways to set this up.
Perhaps the very easiest is to use one rack per input, and then put all four racks into the "Bounce to disk". Hit record and lay out your beat!
But if you want it directly into a sampler or looper, you can set up a polyphonic sampler. Set it to four voices and then you will also be good to go.
And then there are the loopers, which I imagine can also do this very well.
theotteryears
Unread post by theotteryears » 27 Mar 2015, 12:55
great, thanks for your replies!!
is there a way to say have each drum mic on its own channel, then run these 4 channels into one sampler/looper?
is it as easy as dragging the drum channels into the rack with the sampler in it?
ceasless
Unread post by ceasless » 27 Mar 2015, 13:07
In this case you could use the Audio Mixer module.
drakh
Unread post by drakh » 27 Mar 2015, 13:08
yep, for each channel setup a separate rack, then create another one rack with sampler, and drag the other racks into input section of this "sampler" rack
Unread post by nay-seven » 27 Mar 2015, 13:09
Yes, you can also create a device for each input, check to Device chapter in the pdf manual
you'll see it's easy
theotteryears
Unread post by theotteryears » 27 Mar 2015, 13:30
thank you very much most excellent people. i will try this out this weekend!
