modulating pitch bend on a vst
Here ahs,
I made you a simple patch with some comments within the patch edit to help you understand.
It is basically two examples using the output of an XY pad to convert to MIDI or different values, and the second is an LFO output to MIDI
I am driving MIDI to the VST in this example, instead of direct however once you start getting the logic it becomes simple to modify for your needs.
Let me know if this helps or not....or you have other questions.
ahs modulation example patch
ahs,
Also it is probably more appropriate to post specific patch questions in the patching questions section of the forum.
This at least prevent confusion and help us keep reference.
-S
-S
but does not help me on my probleme
i go to the patch forum now
No worries Ahs!
Regardless, you now have at least some commented example to help you build some MIDI with, or learn how to adapt some controls once you get your pitchbend question resolved.
I see Nay and Drakh are helping. I will leave this to them.
If you have any questions about the patch I sent you, you can go ahead and address them here help you get going with HH.
-S
-S
Users browsing this forum: Bing [Bot] and 541 guests
