Aux tracks
lalo
Unread post by lalo » 17 May 2006, 09:48
Hi guys,
i didn't not well understand the aux tracks...
how to create explicitly one?
at present i select the "aux" input for a track that i want to work as an aux...is it the way it is supposed to work?
Unread post by senso » 17 May 2006, 10:16
Aux are very similar to aux busses in real mixing table.
You send audio from any track to the aux1 (or 2) and then create a new track with aux1 (or 2) as input.
Typically:
you put a reverb effect on a track with the aux1-2 as input.
You send the sound from other tracks to the reverb by adjustement of the aux1-2 fader of each track.
hope i'm clear...
lalo
Unread post by lalo » 17 May 2006, 10:22
..so i got it :)
6 aux busses? :)
as my mackie mixer? :)
unguitar
Unread post by unguitar » 21 May 2006, 13:23
Is it possible to set the input and output hardware channels to route an Aux in/out ?
thanks,
luca
______________
luca
www.unguitar.com
lvr
Unread post by lvr » 06 Jun 2006, 13:14
lalo wrote:at present i select the "aux" input for a track that i want to work as an aux...is it the way it is supposed to work?
Same question as Lalo. I do the same way. Is this the way it is supposed to be done ?
Unread post by senso » 06 Jun 2006, 21:49
If you select the aux(i) as input it means that the track receive the sound from the aux bus (i)
There are only 2 aux busses.
I know, it's a limitation but, we have to take care about the CPU load. (Everything as a cost...)
For more funky routing you can use: the global constant module.
lvr
Unread post by lvr » 07 Jun 2006, 00:48
Ok Thanks for the answer. I have to check that. What would be the use of the selected output in a track that has an aux as input... ?
Unread post by senso » 07 Jun 2006, 09:38
No problem!
Gybe
Unread post by Gybe » 24 Jan 2007, 19:38
Sorry to use this post but my question is all about Aux.
I understand what is said above and I want to use the same example with the reverb :
- I use a sampler patch on my 2 first tracks
- I want to add a general reverb to them thru Aux buses so I use the aux 1 fader to adjust the level of sound for track 1 and 2
Question is...where do I add my reverb patch ? How do I "edit" Aux 1 ?
I just d'like to know where to find them...but maybe it comes from the free version I use.
Thanks for your help and sorry for being such a bother but I'm still experimenting under Usine (it's been 2 weeks now).
bmoussay
Unread post by bmoussay » 24 Jan 2007, 22:25
Hi Usiners!
Just some thoughts about AUX buses.
I think two AUX (like it is now) are a good number (in a matter of CPU and screen real estate saving).
Personnally I use a lot the "send to audio or midi bus - get from audio or midi bus" modules to add Aux buses when more than two needed, these modules allow really crazy routing.
Also I use the "additional audio in - (out)" modules to do some "hardware aux busses": for example
Track 1: input set to AUX1 - output set to OUT1 (my master out),
then on this track a patch with:
"audio in" -> "additional audio out" (set to an output of my sound card linked for instance to a hardware FX)
then "additional audio in" (set to an input of the soundcard receiving the hardware FX) -> "audio out"
Then any other track can easily send to track 1 via the AUX1 Fader.
Just to aswer Gybe: to set up your reverb in the AUX1 bus, simply create a patch "audio in -> reverb -> audio out" on a track then set the input of this track to AUX1 (and of course the output of the track to your main out).
Rgds,
B.
Gybe
Unread post by Gybe » 24 Jan 2007, 22:31
bmoussay wrote:Just to aswer Gybe: to set up your reverb in the AUX1 bus, simply create a patch "audio in -> reverb -> audio out" on a track then set the input of this track to AUX1 (and of course the output of the track to your main out).
Ok, so that's how it works ! ... I get it now. I had just found how to use the "send to audio/data" stuff that works fine too
Thanks for your help...sadly more questions to come but in another topic !
