my using is very grained as it doesn't support the screen resolution of my mac. Any case out there and/or solution??
USINE HOLLYHOCK RETINA SCREEN PROBLEM
Usine supports retina displays.
moreover, usine is developed on a retina mac...
so you pb comes from elsewhere.
can you post a bug report with your logfile and scren shots?
thanks
thanks
here's a screenhot
http://www.sensomusic.com/forums/upload ... .56.35.png
(if useful)here's my desktop for a comparison
http://www.sensomusic.com/forums/upload ... .55.30.png
Thx
Thx
Nothing suspect on your screen shots
Usine use the basic retina mode and divide the resolution by 2, like almost all softwares, especially audio.
Also, inside usine we took the option to minimize antialiasing and so get the max of cpu for audio not for display. It's a choice, we can discuss about it but, the more you have resolution and fx, the less you have power for audio...
Thank you Senso,
I agree that is better have more power to CPU for audio than other things.
Users browsing this forum: No registered users and 996 guests
