scroll in IB
Hmmm tested quickly and I see a tiny scroll bar there : ) Your Usine in full screen mode, right?seamus wrote:Perhaps I'm stupid but in IB mode i lose the scroll wheel. It would be nice to able to scroll along through some different interfaces as my touchscreen is small. Am i missing something?
thats strange because no matter what i do i don't see one. i get the scroll bar in the normal racks view but not the IB window
be sure to not have "auto reorganization activated in the IB , then place objects or patches on the right of the screen, the scroller appear when objects exceed the right edge
you can then adjust the properties of the scroller
Wow I could have sworn I tried all that. I will check again tomorrow and test one more time.
Thanks for your help!
I have the scroll bar for left > right but no scroll bar for up > down. It's fine except when I am zoomed in the interface and want to scroll down. This is windows 7x64 on Lenovo x220t.
@gurulogic: normal, cause there's no vertical scroller
ok thanks i found it finally. I wasn't persistent enough! thank you Nay!
it could be nice to have the scroll functionality work the same way as the windows start screen. it is possible to drag anywhere in the background and navigate without having to use a scroll wheel. this would be ideal in IB mode i think
Users browsing this forum: No registered users and 334 guests
