No "recents" on the start page
XpiR
Unread post by XpiR » 09 Jul 2014, 16:18
Hi
Since I downloaded Usine last version, I lost the "recents" column, I only get the "demos" & "templates" sections on the start page
I don't find any tuning for that...
What's the trick ?
iococoi
Unread post by iococoi » 09 Jul 2014, 16:24
did you copy the config folder from your previous version?
Update
Unzip the new version as describe above then process as follow:
Windows: copy the old /Config/ folder from the old version directory to the newest location.
MacOSX: [right-click] on the .app package and choose “open package content”. Then copy the old /Config/ folder to the newest location.
XpiR
Unread post by XpiR » 09 Jul 2014, 17:29
Yes I did.
I have all my personnal patches & workspaces stored as usual, but no "recents" as described...
To be more precise, if I work on different workspaces without closing Usine, then the "recents" column shows up with the used worspaces.
But if I close / restart Usine, no more "recents" menu....
Unread post by nay-seven » 09 Jul 2014, 18:49
and in your config/recent/ folder you have the correct recent text file...?
XpiR
Unread post by XpiR » 09 Jul 2014, 19:27
OK I now solved the issue.
I newly run Usine on Windows8 64bits, and Usine was located my "program files (x86)" which seems to be dedicated to the 32bits programs. Moving it to "program files" solved my "recents" problem which happened to appear again...
But...
I had a second problem : each time I was doing a [CTRL+Z] to undo an action in the patch window, the patch was totally cleared... I could I only get it again with a "reload workspace".
I had :
Workspaces, patches etc stored in partition D:DATA.
Usine folder stored in partition C: OS.
Moving again Usine folder to this D:DATA partition - i.e. the same partition than the workspaces - completely solved the problem.
So the solution seems to be : all Usine items on the same partition...
Unread post by nay-seven » 09 Jul 2014, 20:25
ok,
glad you solve this
must be specified to 64 bits system, i will try to reproduce this
Users browsing this forum: No registered users and 449 guests
