Suggestion: rewrite engine for 64 bit
Newbie Brad
- senso
Actually Usine has a 32bit engine and in some parts (like audio filters) 64 bits.
My opinion is that 32bit is really enough for most audio applications and will always cost half than 64bits in CPU, memory access, etc...
Isn't it only a matter of marketing?
who use 192KHz/64bit?
Newbie Brad
I'm not smart enough to know. I just like if there is a computer capability then exploit it with the software if it will increase ability to do work. I see Reaper is 64 bit engine and admire; it seems most efficient.
