Hello Nay 7
I use the grid and I need the switch on / off on the rack module in the patch window.
when the rack is active by the grid, the module's led is on. that's ok
but when the grid unactives the rack, the module's led stays on.
I need it to be off
could you check it ?
thanks to take a look
rack module on/off
by default , when rack is inactive in the grid,,rack if Off so nothing is calculated, so not easy to display its state
so if you want to see the state of the racks, you have to create a specific rack , always active in the grid and use the rack module
here an example
Download
And if you can, please use the patching forum for this type of question
here an example
Download
Users browsing this forum: No registered users and 453 guests
