aligning UI elements - same size
parityflux
Unread post by parityflux » 21 Mar 2014, 16:43
Is there a simple way to:
1) make a group of objects (faders or switches) identical in size
2) align a group of elements either vertically or horizontally?
...without manually editing each object's parameters (not a simple way)?
..either in the IB or right in the racks.
I've used the snapshots but that doesn't appear to maintain size information.
Thanks!
drakh
Unread post by drakh » 21 Mar 2014, 16:45
1 -define a constants and patch them to GUI controll pins on your modules...
parityflux
Unread post by parityflux » 21 Mar 2014, 23:48
whoah. cool! If the controls are in different racks/patches do I need to make a data bus for this?
-j
Unread post by woodslanding » 22 Mar 2014, 06:56
I have long wished that you could select multiple items, and edit all their parameters simultaneously.
The inspector would only show the parameters that all the items had in common, obviously. I remember this feature as far back as the ensoniq eps in the late 80s, kontakt has it now..... I seem to remember it from various IDE's as well.
Then you could select a bunch of items and give them the same height or vertical position or value range. Would speed up patching and layout tremendously. Of course you would also need a method of selecting multiple items from the graphic views, since it's impossible to select items from different patches simultaneously in the patching window...
so maybe someday..
La Tenaille
Unread post by La Tenaille » 22 Mar 2014, 12:29
I suggested such an improvement here
I think too that design and texts management could be more friendly ;)
Users browsing this forum: No registered users and 233 guests
