Hey,
a while ago my Presonus Firebox exploded and now I only have an old USB-Mixer from Yamaha left ("MW12").
It's pretty limited and only has 2 ins and 2 outs with 44/48 khz @256 samples.
It works in every other audio software I have without any problems, I can select it in the Usine HH setup and it looks fine but when I try to start the Audio Engine, I get: "Warning: Audio Driver not started, Please choose it in the setup" - which I already did of course.
I also restarted Usine.
Any Idea what could be wrong?
This is the 32 Bit version on Windows 8.1 Pro x64.
Thanks for any hints,
Cheers,
Tom
Sound Device doesn't work with Usine HH 1.1.001
Thomas Helzle
Now I tried the 64 Bit version of Usine which seems to work.
Curiouser and Curiouser...
I have it working in other 32 Bit software just fine?
Cheers,
Tom
Cheers,
Tom
i also encountered this behaviour with both the 32 and 64 bit version. i suspect some shared audio driver hick up might be responsible for this.
Thomas Helzle
http://www.sensomusic.org/forums/viewtopic.php?id=4292
Yeah, several people with this is seems.
Well, maybe one day I'll get lucky and have Usine actually working
Maybe next year.
Cheers,
Tom
Maybe next year.
Cheers,
Tom
This new version has solved a lot of sound card problems, but of course , we can 't test all of them, can you please use the report bug page ?
Thomas Helzle
No, isn't important really, I just thought there may be a quick fix...
Cheers,
Tom
Cheers,
Tom
Users browsing this forum: No registered users and 348 guests
