Question: Time horizon for Usine as VST?
hesspet
Unread post by hesspet » 06 Jan 2014, 14:23
I was asked to join to a project. One of the preferences is to use Ableton Live and we had a discussion to use some of the great skills of Usine. It's simple to make a connection via Midi/Osc - but an audio connection? The setup should run in a live environment, so hacks with virtual audio are not a good solution, due to the latency problems and the resource sharing.
The question: Is there a roadmap to bring back the feature "Usine as VST". I don't mean a definitive date. More a info of "this year" "next year" :-).
It's a long term project.... and I will not give up the "Usine way"
I'm also interessted how others solve such a combination :-) Ableton & Usine.
Users browsing this forum: No registered users and 411 guests
