MIDI learn : how does it work now ?
La Tenaille
Unread post by La Tenaille » 22 Nov 2013, 09:49
I've read that the MIDI learn staying on wasn't a bug, but I really can't see the way it works now, because the only way I've found to turn it off is restarting Usine :/
The manual has no mention about this "new feature", and I don't find it helpfull at all...
Unread post by nay-seven » 22 Nov 2013, 10:28
Now, the midi learn menu button let you record several midi learn, useful for Midi controller with many knobs to assign.
you click once, assign all your knob /faders click again to stop..?
btw, i know I've to update the wiki page about that, sorry
La Tenaille
Unread post by La Tenaille » 22 Nov 2013, 10:54
Ok, it seems to work for me with the menu button (ctrl+M), but is it supposed to work with the contextual menu (right clic on the object) ? I always use this method because it gives instant access to the MIDI message stored, mode, clear learn etc... and this midi learn button doesn't seem to toggle.
Unread post by nay-seven » 22 Nov 2013, 11:22
ok, you're right , we have to investigate on this method, maybe not clear..
thanks
La Tenaille
Unread post by La Tenaille » 22 Nov 2013, 11:42
Merci Yan :)
