Synchro with internal clock
- cmodica
- senso
There is no direct way to get the absolute time.
I've just posted a simple add-on which get the absolute time in HH/MM/SS.
But each time you start the patch you have to enter the current time; then the patch calculates the new real time.
Not a real solution,
I'll add a new module to get it more easily...
- cmodica
OK, thank you Olivier, it is cool !
- senso
The actual version of the add-on is probably not enough precise.
Replace the [timems] module by a interface Control/time/[Precise time ms] and divide the result by 1000 to have it in ms.
I've just created a [What time is it?] module, next release, this afternoon, I hope.
- senso
I think that the alarm clock patch will be easy to create with the new module.
- cmodica
It will be very great, because i want to use Usine for a sound "installation" that i had to do for the end of november. And the firs test that i just have been doing with your patch are very cool !!
Thanks a lot i love this soft more and more.
